Tail lights
MMJQ45
Car: 1991 Q45
My tail lights are not working. i've replaced the turn signal switch but the problem remains the car is a 1991 q45...no tail lights or rear side marker lights any help would be appreciated
Q451990
Welcome to NICO!
Check your sockets, and the fuses. It's a pretty common issue...
zerothread?id=102649
MMJQ45
Car: 1991 Q45
Yes it was a fuse. for some reason i missed the first row of fuses that run vertical. thanx alot.
Q451990
Glad I could help! Please go ahead and take the time to check and replace your brake lamps if the lead tips on the bulb base look deformed or melted. Failing to do so risks toasting the brake sensor and/or causing your brake lights to go out without your knowing and causing an accident.
Heath
