liquid_cool wrote:ya thats a short.....i had this same issue...when you tilt the steering wheel in the uprite position the wire harness for the running lights may eventually get cut and ground out ...it happens on a sharp part under the tilt part..rite at the edge of it....what i did to solve it..was to epoxy a soft piece of rubber on the edge to stop the wires from being cut...this may not be your issue...but it is a common one..so look there first..try pulling the wire away from the spot..replace the fuse..then turn the running lights on..if the fuse pops again..keep looking..if it dosent..then you had the same issue alot of us have had...hope this helps.
I am having this same problem, I went trough a whole box of fuses. Tonight I riped apart the whole dash and didn't find a short and no shorts at the lights ether. Could you post up a pic of where this wire gets warn through. I am going crazy, so crazy that I have thought about making this strictly track car.
