Tail Lights Fuse Blowing
General discussion area for the L32-chassis Altima
thegamingwad
Car: Nissan Altima 2011
I recently installed a boss radio into my 2011 nissan altima and since then ive been noticing that my tail lights have not been turning on. The brake lights work and the bulbs are not burned out or ruined. The lights for the glove box have also stopped working. I have checked the fuse and seen that it was blown, so I put in a new fuse and it blew too. Any ideas on why this might be occurring?
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Which wire did you tap into for dimming? Did you use a conversion harness or DIY hack and slash method? It's possible you tapped into the dimmer wire for your main power and are overloading the fuse.
thegamingwad
Ace2cool wrote:
Thu Nov 09, 2017 7:47 pm
I used a conversion harness and i didnt connect it to the dimmer due to the radio shutting off when the lights were on.
Ace2cool
Then it's 100% connected wrong. Main wires to check are constant voltage, dimmer, ground, and ignition.
Return to “4th Generation Altima Sedan (2007-2012)”
