tail lights died!!help!!!
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
bracktheron720
Car: 1984 720 with 1980 datsun front end,1972 yamaha cs3
so iv been workin on the body of this beast for a while now just about got it done..but anyways i decided to run down to the gas station in it and get smokes and a case of bear and a guy pulled in behind me and told me i had no lights in the back at all....they worked when i parked it a couple weeks ago.....???the only other thing i did was put a new battery in it.. iv checked the fuses and there all good...but iv got no blinkers,running,break,reverse or plate lights!!!any ideas or anybody had this issue and fix it that give me a hand?????
bracktheron720
so i checked my fusible links today and there all good...they have power all the way down to where the harness all comes together.....thats the last thing i can think of........any ideas i could really use sum help on this one im kinda lost when it comes to electrical stuff...
offroadbob
Car: 96 240sx, 84 720 4x4
My lights died on my truck too a while back. check the wiring all the way back. some how mine were sliced by something. it was pretty odd. nothing a little solder and some shrink tubing couldn't fix. hope that is the case with yours too. good luck!
dogred
Car: 1983 D720
Check all of your bulbs and the connectors. Had this problem with my driver side blinkers, bad connection with the bulb, cleaned it up and they worked. Will check my wiring diagrams later, right now at work.
bracktheron720
woot woot!!got it figured out!!theres a plug under the passenger seat that hooks up everything in the rear of the truck into the system it wasn't connected all the way.... plugged it all the way in and got all my lights and fuel gage came back!!! didn't even know it wasn't working also..lol thanks for the help!!!!!cant wait to get back on the road!!
brianzero
Car: 1986 Nissan 720 4x4 Regular Cab 265,000 mi! (Gasser unfortunately)
You lucked out. I have this problem and have been trying to figure it out for months. My solution isnt gonna be that easy...
bracktheron720
dang thats no good man...let us know how it turns out...im guessing youv already checked the plug under the passenger seat...?
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
brianzero wrote:I have this problem and have been trying to figure it out for months
I had this problem when I got mine. I checked all the bulbs and connectors. The problem was where the wires pass under the tray over the diff. They were severed there. Take your time and do a complete check of your wiring. Clean all connectors and check your bulbs. Not all at once, so you'll know where the problem was.
Return to “Datsun 720”
