fyarf »
https://forums.nicoclub.com/fyarf-u259099.html
Mon May 23, 2016 6:30 am
LEDs have a much lower resistance than incandescents. You will basically need an inline resistor to equal the factory resistance if you have problems. For reference, most LEDs run (at least indicator LEDs on an IC) run around 200-800mA. Any incandescent requires higher power, which is Power(or Wattage, wattage is power)=I^2R. Test it out, you might not have any problems. If you do, there will be guides on how to fix it.
