tail light running light fuse keeps blowing
24j0hn
Car: 91' 240sx with some babying to be given
its a 15A fuse for the tail running lights... i put a new fuse and it blows right away...
wat do i do?
tctomasc
Car: 95 240sx
check for shorts in the wires....
jdm_240$x
Car: 1990 nissan 240sx
check this out mine did the same stuff.when you turn them on there fine.when you turn them off and them flip the switch it want work right???wat i did is looked under the tail light cover and followed the wire over by the corner panel and thats were the 2 bare wires was touching at so check around the back of your tailights
maj Andres
Car: Zenki, '95 Model, w/ S14SR20DET
are any of your interior lights working?
zerepdivad
Car: '90 240sx . '02 Lexus IS300
Radio illumination wire.
maj Andres
Damn you! I was getting to that. How you know? I had this same problem.
AZ89two4Tsx
Try changing the oil and putting 91-93 octane in it.
Papi Chulo
Car: 72' Datsun 510
AZ89two4Tsx wrote:Try changing the oil and putting 91-93 octane in it.
This only works for models 95 and newer.
AZ89two4Tsx
Silly me.
