tail Light Mod
94_240sx
Car: 94_240SX
ishkabibble wrote:Thanks, I'll see if Autozone has those 1157s in red.
I like the amber bubs on the turns! Plus, I wouldn't pass inspection without them.
It's amber when it's lit. There's a special silver coating on amber bulb. You will pass inspection with no problem. It adds cool looking to the rear end.
ishkabibble
Car: 1992 Nissan NX2000 hardtop
1993 Nissan NX2000 t-top
1997 Infiniti I30t
I see. I don't mind the spot of amber on a red car, but if I had different color paint, I'd probably think it looked bad. Def going with the red 1157s though.
nightkid86
Car: 97 S14 SE
amber blinkers don't get that hot since they arn't used much and flash on and off, so you can just do a thin mist of silver high temp engine enamel over the bulb. They will be silver but light up amber.
zer013
Car: 1993 Nissan 240SX Convertible
cmkelly wrote:Here's a simple mod that to me looks cool - Replace the stock tail lights. I looked at the smoked ones too but liked the clear cuz they looked more like my Pathfinder. Trying to keep that family resemblence...
Remove the plastic panel in the trunk that's held down but little plastic screw/rivit things. You can pop these out with a flat-head screw driver and pliers. Be careful, you'll need them again.
Once the back plastic panel is removed take off all the 8mm nuts you see holding the tail lights and "240SX" bottom peice in place. You need to take this trim peice off to have better leverage when removing the lights.
those tails look good
94_240sx wrote:Yup!!I think red tails look definitely good.
i like my all red tails
zenkii
Car: 95 240sx
thats hawt
