centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Tue Jan 23, 2018 1:01 pm
Hi dewars, welcome to NICO Club.
It sounds like the passenger rear corner lights aren't working, but the brake lights are. Try running the car and turning off all the lights, then try your brakes, then turn on your lights to ON with headlights ON, not Auto, check your corner lights. Try the brakes and check again. Try to determine if the same LED bulbs are used for both the brake lights and the corner lights, or if they are separate. If they're combined, then something is up with the wiring. If they are separate, then you need to replace the light assembly.
Please let us know what you find.
