proxim2020 »
https://forums.nicoclub.com/proxim2020-u47252.html
Sun Jan 21, 2007 6:06 am
Behind those plates should be 2 nuts securing the lamp housing to the car. Remove those to remove the housing from the car. There should be a connector on the back of the housing. Remove that connector. Once you have that out, you should be able to turn the bulb counterclockwise to unlock it.
