Tail Light Assembly -- 1995 Nissian Pickup XE
Cobbscout
If the turn indicator blub is out, do I have to replace the entire tail light assembly or is there a way to only replace the blub.
In the past when a bulb (break light, turn light, etc) has gone out, I've replace the entire assembly ($80 per). It's expensive doing that.
Now the turn indicator bulb is burned out and I'd like to be able to just replace the blub but don't see how because of the way the assembly is put together.
Any suggestions?
(And thanks in advance )
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
You only have to replace the bulb. The mounting screws are inside the bed in the back corners.
