Ace2cool wrote: I would actually love to dig into a schematic of the voltage regulator/sensor, but haven't found one. The closest thing I came across was a complete wiring diagram that someone posted up here ages ago, and I wouldn't know where to even begin looking for that. Therefore, I can only speculate as to how it works, but I believe I have a decent understanding from my experience with the tails.
I've looked at a complete vehicle wiring diagram,
http://www.300zx-twinturbo.com/cgi-bin/manual.cgi, and it looks like the sensor has about 8 inputs. Sounds like a bunch of wires, but I've never seen the sensor.
Ace2cool wrote:I believe the way it operates is by measuring how many volts are dropped from each individual tail light bulb, and by comparing the input/output voltage of each individual bulb, determine the resistance of the bulb, and if it measures out of spec, throw an indicator light to the dash. As you stated, when a bulb burns out, the resistance goes up and up until it becomes infinite. That would indicate bulb failure.
However, if resistance drops, that indicates to the sensor that there is a short either in the wiring somewhere between the sensor and the bulb or IN the bulb itself, also indicating failure, since insufficient volts were dropped to power the bulb. As we all know, LED bulbs have much lower power requirements than traditional incandescent bulbs, since they produce less heat. Therefore, the sensor reads the lower dropped voltage on the LED's as a short.
I don't want to seem like I'm being critical, but... When measuring resistance, you cannot have power on the circuit. Seeing as the lights appear to be in parallel, input voltage is the same across all lights, so voltage drop would be the same weather or not a light was there. The only reason that I referenced this case in my initial post was to entertain the theory. I think in practice that this may be a bad idea, because as long as there is a complete circuit the light would remain off. So, the issues with corroded bulbs and improper resistance bulbs shouldn't occure.
So correct me if I'm wrong, but the bulb out light only comes on when the break or tail light is on. So, this should automatically rule out resistance. Also, making an assumption that most circuit designers use on higher voltage low current circuits, wire resistance and such should be zero. This kinda rules out the voltage. I did like the voltage drop idea from above, but if the lights were wired so this would work, it would be all or nothing.
I believe that I may have answered my own question, but I'm still at a loss for the actual case. The wiring diagrams only seem to show the sensor in RH drive models.
As far as the circuit itself, it is true that if resistance and voltage remain the same as the original circuit that current would have to remain the same. V=I*R.
Ace2cool wrote:The easiest and simplest solution, IMO, would be to test the dropped voltage on both the low and high circuits on the incandescent bulbs and use resistors to try and emulate the same dropped voltage from each. May I inquire as to the design of said LED taillights? Will they be simple "bulb" replacements or a full LED board? The bulb replacements would be easier to simulate dropped voltage on, seeing as you could deal with each "bulb" separately.
Currently I'm entertaining the idea of designing full drop in boards. I'm hoping to be able to fit the board between the reflector and diffuser. Granted, I have absolutely no idea how the diffuser is held in, so design modifications will be hit and miss.
With the full board, I plan on adding pigtails and a connector to utilize the stock harness. This is for ease of removal/install, and should have the added benifet of making it easy to reproduce if others are interested.
Personally, I don't like the stock layout, so I have modified it a little bit. Here is a proposed layout.The blinker will make the bottom lights blink high/off unless the brake light is on then will blink low/high. This will make more lights on during braking and at night, hopefully increasing safety and coolness.
I've been using PSpice to design the circuit, and am working out some of the bugs. The major one that I am currently facing is will I have to use a constant current driver to push the LED's or will I be able to use a voltage driven system. I am worried that the voltage swing (10v-16v) may not allow the LED's to operate properly. Either the voltage will be too high and the LED's will go poof, or the voltage will be too low and the LED's will not light. Then there is the issue of having the high and low states. More than likely, I'll resort to doing the controlled current setup. It's really not that big of a deal, will result in a more even light output across voltage levels, and will keep the LED's safe from voltage spikes and such. Keeping it all cool could be another issue. Contrary to popular belief, LED's do generate heat. They are only about 20% efficient (vs. 2% for an incandescent). Between 90 or so LED's and a good deal of circuitry, I may not be able to do a stock drop in.
Any comments or suggestions will be taken into consideration. While I've been working on the electrical side and can do the electrical modeling, I (or my friend) don't have the funds. He gave me his old set of stock lenses (he bought J spec lenses) but I haven't had the chance to dissassemble them. This will be an extremely slow work in progress, as I don't plan on doing anything physical until I get a circuit designed. Then there will be a prototype and a final design. The end goal is to have a circuit board printed made then all I have to do is solder on parts.
