mattlord42 »
https://forums.nicoclub.com/mattlord42-u3094.html
Thu Feb 27, 2003 5:45 pm
Okay, I don't know if it is the same on the S14 as the S13 but a couple of us had this problem in our '90s after swapping stereos. The problem there was that there was a red wire with blue stripe in the harness that tested as a ground but when you used it as your stereo ground it would blow the taillight/gauge cluster fuse. The solution there was just to make a new ground. Just might be something to check if you just swapped head-units.
Matt
