tail, dash, a/c, and plate lights dont work 240sx
Joshua_falcon
Car: 1989 Nissan 240sx HB
so i've been looking and looking all over the web and cant find a solid answer, all those lights do not work i have checked all the fuses swapped out relays and even swapped that little white box (by the fuse box) and nothing have no idea what the problem is. if it matters its a 89 240sx with a DE swap. :wtf2:
xweav32
Car: 2011 Nissan Versa S 6spd (daily)
1995 Nissan 240SX SR20DET 5spd (fun car)
do you have an aftermarket radio? if so the orange wire from the factory harness (its the dimmer switch contol for the factory radio) may be grounded out. thats a fairly common problem. if its not that then since youve checked everything else is time to trace wires
Joshua_falcon
...solution, there's a relay by the pedals that over time jiggled itself out, or i might've kicked it. it was out plugged it back in. and boom problem solved
