CanuckQx4https://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113Tail bulb has 3 wires, which does drive, other does brake...Tue Mar 01, 2011 12:30 am
Postby
CanuckQx4 »
https://forums.nicoclub.com/canuckqx4-u160090.htmlTue Mar 01, 2011 12:30 am
Hey guys, quick question as I cant find anything in the FSM refering to the function of the taillight itself. On the QX4, it is a 2 bulb setup in the taillight. Top 2 wire bulb does signal, and bottom bulb does drive/brake
Postby
Chuck Tribolet »
https://forums.nicoclub.com/chuck-tribolet-u120862.htmlThu Mar 03, 2011 5:58 am
I have a manual that covers both 2001 and 2001.5. It shows the same color code for both. It says:
Smart entrance control unit has been changed.
I The SMART C/U - PREVIOUS is applicable for the 2WD models up to serial number 567231 and for the
4WD models up to serial number 584967.
I The SMART C/U - NEW is applicable for the 2WD models from serial number 567231 and for the 4WD
models from serial number 584967.
Postby
Pwnin O'Brien »
https://forums.nicoclub.com/pwnin-o-brien-u136941.htmlThu Mar 03, 2011 11:21 pm
That is weird, it should be Green/Yellow for stop and Purple/Black for running lamps. I would take Chucks suggestion, Green/Yellow is most definitely for stop lamps.
