Tail as Turn M56/37
SnowNYC1
Car: 2006 Infiniti M35x
2011 Infiniti M56x
So today I did the tail as turn mod on my 56. It wasn't too difficult to do and only took me around 40 minutes.
To do this you will need the following:
Tail as Turn mod from Diode-dynamics along with the led resistor kit that they sell:
https://www.diodedynamics.com/tail-as-t ... e-diy.html
Wire stripper and crimper; power probe.
Step 1: Remove the trunk trim around the tail lights to get access to the wiring harness.
Step 2: Disconnect the harness to get access to the plug pins. The plugs are 1-4 left-right
1-Ground 2-Turn signal 3-Brake 4-reverse
Step 3: Cut the turn signal wire and brake wire and strip them.
Step 4: Insert the turn signal wire into the yellow cable and the brake into the red cable on the turn by tail module and using the crimping tool squeeze the ends together, that way the cables will not fall out and you have a solid connection.
After that, take the other end of the brake cable that's on the side of the harness plug and insert it into the wire crimp connector on the other end of the module. There will only be one cable on that side of the module
Test your turn signals to see if they work, They will be hyper flashing which is why we have the resistors to fix that.
Step 5: Take the LED resistor and with the included T-taps, marry one end of the resistor to the black ground cable (terminal 1) and the other end further into the turn signal cable (preferably before the module connection). This will solve your hyper flashing issue.
REMEMBER: The resistor will get super hot so make sure you mount it in an area not near other cables or trunk liner fabrics
The steps for the other light are the same, the wire colors will be different, but the pins are the same.
End result:
Have a good one!
Ilya
How does it work when you're braking? Only the opposite side and 3rd brake light turn on while the blinker continues to blink at normal brightness?
SnowNYC1
2011 Infiniti M56x
let me see
SnowNYC1
2011 Infiniti M56x
Ilya wrote:
Fri May 08, 2020 4:52 pm
thats exactly how it works
Yoda's Master
Car: 2012 M56
2009 370z
Are your hazards in sync?
SnowNYC1
2011 Infiniti M56x
Yoda's Master wrote:
Fri May 08, 2020 6:57 pm
yup everything works perfect
Larz
Car: 2019 Q70-L RWD
What will become of the orange turn indicators? Can you replace the orange bulb with a red LED and have them blink as well? or do you just leave them and no longer use them?
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
That's an interesting concept Larz. Most people turn those spaces into additional reverse lights
SnowNYC1
2011 Infiniti M56x
Larz wrote:
Fri May 08, 2020 9:33 pm
No idea yet, i might just make super bright reverse lights or maybe a red led as you brought up. no plans for now though.
Ilya
I also wonder what this does to the life expectancy of the LED lights...as they were not designed to turn on/off like that. LEDs typically have a really long life so maybe it's a moot point.
Kawasaki 0
Car: ???
SnowNYC1 wrote:
Fri May 08, 2020 2:57 pm
End result:
Have a good one!
Can you post pictures where you mounted the LED resistor?
