tacometer goes crazy at high speeds
LeroyBrown
Car: 1995 nissan 240sx s14 blacktop
at regular speeds it is regular once in a while it will jump around but on the highway it jumps around.. what do i need to fix? is it hard? iv never taken apart a dashboard
dblanehopr
Car: 93 primed black fastback
It depends on what's causing it. There's a chance it could be a loose connection because the tach is electrically operated. I don't want to go too much futher into it because I've never looked at the wiring diagram for what controls the tach. I think it's ran off the transmission because I don't remember anything on the engine that would control that. But I'm not sure. I've never looked into it so far.
Now I'm curious. lol
Piper
Car: 96 240, the new toy.
93 Vert, gave to my bro... for now,
91 HB, brother totaled,
27 other 240sx's in total, all gone now!
1 check your ecu connection. if you have moved or taken off your ecu or someone else has, when you hit bumps, it will jar it and lose connection.
2 if you have taken off your cluster or maybe someone else has, your pins on the back of it are very touchy and easy to break/bend. make sure all clips are on and correctly touching contact pads.
3 if those all fail at fixing, try replacing it with a buddys cluster and see how it works for a week or two.
LeroyBrown
its not the ecu it did it when i had the ka24de now it does it with srdub ecu to
leonelrr
Car: s13,s14, z32TT, YZF R6 None of them work nothing to brag about
MAYBE BAD SPEED SENSOR?
romerider153
Car: twin turbo vh41 tube chassis s13, s14 and s13 ka-t daily, someone buy my s14
speed sensor has nothing to do with the tach the tach is controled by the cam position sensor on an sr that info is sent to the ecu and then sends it to the tach i would look for a wiringproblem thats what it sounds like my guess is some were between the tach and the interior plug that connects to the engine harness.
dblanehopr
thinking it's where the cluster attaches to the harness? question is: does the rpm jump up and down randomly or up to the right rpm and then down to a random lower rpm? ..as if the connection on the tach is fading then coming back.?
LeroyBrown
up and down rapidly
dblanehopr
no, i mean is it going up to the correct rpm of the engine and then down and then back up to the correct rpm?or is it just randomly going up and down rapidly with no consideration to the engine rpm?
LeroyBrown
lower speeds it will be normal but when i drive on the high way it goes all over the place...now it doesnt work at all..
