amc49 »
https://forums.nicoclub.com/amc49-u275146.html
Mon May 20, 2019 5:06 pm
Section/page EC/7 page 159 and the lower right hand corner to find ignition coil. Dwellmeter one lead is a ground anywhere under hood and the other taps in right after the condenser and before the coil ground joins with injectors, the coil ground is wire #36 to the ECM. A typical dwell meter joins into coil primary ground after the condenser. Do NOT use the coil output to the plugs, a dwellmeter uses the primary volts not secondary which are 100X stronger and can damage the meter. The wire to resistor is the coil power (12 volt) lead in. Condenser side is primary ground out.
Make sure dwellmeter is switched to 4 cylinder.
