Tachometer - Speedometer Illiumination Out
theska
Car: 2002 infiniti q45 w/premium pkg 180k miles
More issues...my tachometer and odometer do not illuminate (but function fine)...the numbers and needles are of course impossible to see at night and almost as bad during the day. I see that there are a number of small bulbs for cruise, etc. and they all work fine. Any idea of what I am missing?
Thank you.
Q451990
Apparently there is a flourescent tube in the instrument cluster... the FSM says to replace the "unified meter control unit" if it's bad. Other than looking cool... and it does look cool... I always thought it was a little odd to have a dark tinted instrument cluster and then light everything up with a really bright light to make it visible, even in the daytime.
Check out page DI-18 and DI-20 in the FSM. If you don't have a copy, you can download it at http://www.phatg20.net
Heath
theska
Thanks, I do have to replace the whole unit, which is a fortune:(
