Tachometer Q!!
userx
Car: 95 240sx
hey, guys, help me out here!i just got a 95' 240sx from some private seller. the miltage is about 11kand it runs pretty well. but the tachometer is a bit crazy. when i hit thegas with normal pressure (gradually accelerating...), it would reach 4,000or 5,000 rpm. if i hit it hard, it would reach the red zone quickly... andthe sound of the engine is large. then it would go back between 5,000 and 6,000rpm. (and it reads around 4,000rpm when at parking shift) is thissituation normal for a 95' 240sx :ylsuper :help :help :help :confused:
userx
Car: 95 240sx
o by the way, tachometer is the RPM meter i think. thanks. help please.
Ender_Zero
Car: '03 Base Z, '91 S13 Coupe
....wowwell, is the engine actually revving that high? and no that is definatly not normal for any 240. ....im trying to help even though your post is really hard to understand
Arrow
Car: 1990 240SX SE - SOLD
2003 Kawasaki Ninja 250R - SOLD
2009 Kawasaki Ninja 650R - corner carver
1998 Pathfinder
As far as my experience has gone with some of my tach problems... Mine might have done something similar to what you are discribing. But that was after I cleaned the MAF and the throttle plate... I don't know what caused it but after running the car a little and turning it off and on a few times it fixed itself...
Also in my case the engine wasn't revving as high as the tach said. I don't know if that is the problem you're experiencing but some more information would be helpful.
Bryants95240sx
the answer to the noise the KA is normally just a loud engine
