Tachometer Q! PL help~~
userx
Car: 95 240sx
Tachometer Qi just got a 95' 240sx from some private seller. the miltage is about 11kand it runs pretty well. but the tachometer is a bit crazy. when i hit thegas with normal pressure (gradually accelerating...), it would reach 4,000or 5,000 rpm. if i hit it hard, it would reach the red zone quickly... andthe sound of the engine is large. then it would go back between 5,000 and 6,000rpm. (and it reads around 4,000rpm when at parking shift) is thissituation normal for a 95 240sx?:thinker :thinker :confused: :help
entity
Anyone else understand what he said?
userx
Car: 95 240sx
thanks for the reply. i dont really know about cars. and i think the Tachometer is the RPM meter. anyone can help? Please
s13EastTN
Car: 91 s13 hatch, 95 Honda Civic
So what your saying is, when you floor it, the engine revs a lot higher and you don't get going much faster? Btw a 95 240 w/ 11k miles is nearly impossible. Try to go into more detail.
Fenvy
Car: 2005 350Z Base 6MT
carfax.com
get your vin checked, could be odometer roll back
entity
I'm thinkin it was prolly a typo, maybe 110k? And if you mash the gas and it revvs up and you don't move, then it catchs up, your transmission is slipping. Also what do you mean by it being at 4k rpm when you're parking shift..are you saying when it's in park, your engine idle's at 4k? It should be at around 750-1k.
PhaneSoul
Car: 89 Nissan 240SX SE Black 5spd Wrecked
95 Nissan 240SX SE Green 5spd s14.5 yay!
if you floor it and it reaches red wuick, and normal driving and u go from say 2k to 5.5krpm's quick and lil to no accell then its ur clutch, but thats if its a manual
entity
Auto's going bad will do that also.
