CrazyAsianBoi wrote:I recently did an SR20DET swap on a 1990 240sx. I have the stock SOCH tachometer and the rpm gauge doesnt work. I did a search and one guy had the exact same problem. The info that he was given and read by me are totally different. His solution to the problem is find pin#3 on the ECU plug and the wire should be Red/Yellow stripping. I went to my ECU plug and found pin #3 and it was a Yellow/Red stripping. The only Red/yellow stripping was for pin #105. I need help here. Is he right? How do I get my rpm gauge to work?
hey man, you should check out that junkyard off of satellite blvd. up in buford near the Oasis bowling center.. i was up there recently and they had a 92 240 there being parted out and you might pick one up there.. if they havent gotten rid of it.
