Grabbed some pics to show you guys what I'm dealing with.
Here is the wiring behind the dash. I don't see the green connector for the clock anywhere.
And here is the yellow w/ red dots under the driver side of the dash
And here is what is on the passengers side. The one connector is ONE wire, the other is TWO. It looks like the one wire connector could fit into the two wire connector on either pin.
And finally, I noticed this while grabbing the last pic, under the center of the dash. Two two-wire connectors not plugged into anything. Are these for option guages in the console?
