Silvia_Drift wrote:Hey guys, I need some help fixing my tach. The car is a '90, with a '96 KA-T installed. I swapped in a DOHC cluster and the tach still didn't work.
The wierd thing is that the signal is coming through to the ECU. When I put the tester on the red/yellow tach wire that goes to the ECU, the voltage was raising when I revved the engine like its supposed to.
I was thinking that maybe the tach was just broken but it seems like this isn't the case. The SAFC 2 isn't reading anything for the RPMs. One thing I did notice is that it is getting a signal for Inst1 and that seems to be the RPM. It also raises when I hit the gas. Any ideas?
Any help is appreciated, thanks.
Modified by Silvia_Drift at 10:34 PM 3/14/2007
The wire you tested... is it red/yellow or yellow/red? The tach wire is YELLOW w/ red stripe. Also how did you test the this wire? Tachometer wire should not read higher voltage when you step on the gas, but rather a faster pulse since it is an AC signal.
Did your tach work before with the old motor in it?
