Tacho issue / Laurel C35 Swap / RB20DET
madnjpn
Car: 2001 Nissan Laurel Medalist
Hi guys, got Nissan Laurel C35 some time ago, it was manual swapped and also engine swapped with RB20DET from R32, initially it had RB20DE.
The issue is, I cannot get tachometer to work, the car is year 2001 and I think that facelift got different half/digital cluster.
I am getting tacho signal from ECU on pin 7 (red/yellow) , but tachometer wire from cluster itself gives out 8v (yellow/violet) So I guess it expects 12v signal. I tried adding 10k + 12v IGN bridge method but still nothing... Anything else I can do before I buy signal converter? I dont even know which one to get. Thanks
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
The 8V from the gauge indicates it already has an internal pullup resistor, so it probably wants an open-collector signal (the ECU grounds the wire but doesn't "push" any voltage). However, it also may want a high voltage signal if it originally connected to the coil and not an ECU. Nissan used a mix of both types in the 90's, so without a wiring diagram it's a crap-shoot. It also may not be responding because the number of pulses-per-rev from your ECU may be way lower than the cluster expects. To test it out, I'd start by spending $10 on something like this:
https://www.ebay.com/itm/386169756730
It's a PWM tester, but by setting the duty to 50% and varying the frequency, you can see if there's a signal speed that gives you a response. If so, a little math will tell you how much you need to adjust the signal. You may be able to do that with a tune or you may need a tach converter. The cheap China PWM testers all have open-collector drive, so it can also tell you if that's a problem. If the tach still doesn't respond then it probably wants high voltage, so you'll want to try a booster and not a converter. I can make some suggestions about what you need depending on what the tester tells you.
