Tach wont work
24_4life
I used to have a ka24e and replaced with an SR with the SR cluster spliced the yellow-red to the yellow-red but it wont work after re crimping it twice i dont know what to do?
where dose the Yellow-red wire go to?
thanks
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
Your going to need a KA24DE gauge cluster, I havent heard of it being done any other way (im not saying its not posible, but just not common).
deejayS13
Car: 2008 G37S Ivory Pearl, 1997 240SX SE Deep Fuchsia, 1989 240SX Silver Green Pearl & Dark Gray 2 Tone
You dont need the whole cluster....just a tach from a KA24DE...I just got mine and I'm so happy now:D
props to gtune4 for hooking it up while I was in class......creezie dreezie in full effezie...dont sleep
deejayS13
sometimes I go from sleepy smurf and morph into sleezy smurf.
wangless
Car: '02 MBP WRX
er? im confused... so the SR tach didnt work? i thought they would... or should. can someone correct or inform me ?
Luke
haha, oh no the sr gauge cluster won't work on the sr!
wangless
Car: '02 MBP WRX
im still confused :(. maybe i should read this post when i have some rest...
Phax
Car: Control dynamics
nismod_rps13 wrote:er? im confused... so the SR tach didnt work? i thought they would... or should. can someone correct or inform me ?
I have the SR tach in my car. I just put it into the USDM gauge cluster. The problem is, it reads 500 RPM fast. There is a little screw on the back of the tach, that I think will let you adjust it. I've just been too lazy to rip my dashboard apart to fix it.
dj_lennon_franz
Car: 1992 240sx
the KA24e tach WILL NOT work on a SR swap into a 240 as the heartbeats are different...and also remember that the SR is direct ignition (which means the SR DOES NOT have a distributor)
get a JDM tach (which looks cooler cause it goes to 9k rpms) or use one from a twincam KA24
gtune4
Car: toonah
exactly
rudee023
Car: '03 Infiniti Q45
Splicing? Just unscrew the 3 bolts on the SR tach and install it onto your stock cluster. Worked on my '89.
gtune4
Car: toonah
you can do this with the speedo, water and fuel too, if you are displeased with any of those. (my fuel meter sucked and and didn't read right, so i switched it with the one that i got in the dohc cluster just to see, fixed.) The sohc speedo goes to 115 where i think the dohc goes to 110? anyway i kept the 115 gauge and just switched out the odometer so it was original.
