I'm having a little bit of trouble getting my turbo timer to work correctly......the timer is an HK$ type 1.
The tach function is working, but not correctly. It reads the same value as my stock 240 tach, which isn't calibrated. I read that pin 7 is the tach signal so that is the wire I spliced in to. Has anybody else had this problem or does anyone happen to know what I did wrong?
