Tach
gibbo
WHen I am driving my tach will bounce around for like a second then go back to normal. This really isnt a big problem but wondered if it was a easy fix. I also have a automatic transmission and want to do a 5 speed swap. I was wondering if anyone knows anyone in iowa that would do this or how much all the parts would cost. Thanx
red240ne
Car: mmm...donuts
you might as well just do the sr20det swap and get a 5 speed with it, bc it will cost around the same.
gibbo
I thought about this but then i read a post which made alot of sense. Who could i get to work on a sr20 or ca18???
Daunttless
I will work on them and I"m only like 30 minutes away from you.
s14=pimpin'
Car: 1995 Nissan 240SX SE S14
gibbo, you lucky son ofa......
you got daunttless 30 minutes away from you, go to him, buy what he says, and you will be happy.
hey Dauntt, did you get my email yesturday? Sent it to your ADT address.
Daunttless
Yeah, I got your email. SOmetime shortly I"ll have a response out to you. : )
FatMans240
5spd swaps arent that expensive if you really look around.....Heres how mine's going
transmission, Crossmember - $25Driveshaft - $14Flywheel,bolts,adapter plate - $12Clutch pedal assy - $9Clutch slave, rubber line - $9Clutch master, lines, bleeder - $10Brake pedal assy - $9
Have yet to buy a clutch but im gonna go with a Centerforce from nopi - $200Figure Ill rebuild the slave and master cylinders - $30?Put a new bearing and u-joints on the driveshaft - $???Dont know about the transmission... is 189k in the rebuild zone?
So far I've spent $90 on this, and I figure if I dont have to do anything to the transmission, I'll spend another $300 on parts for the swap. $400 is about average or even on the good side for a 5spd swap I think.:icon18
Aries
Car: LT1 240SS
yes, $400-$600 is about right for a 5 speed swap if you do it yourself from used parts.The parts are fairly easy to come by, and the work is simple enough (2 out of 5 on difficulty).Jsut don't let some rice shop charge you $1800 or MORE to do the swap.
s14=pimpin'
Daunttless wrote:Yeah, I got your email. SOmetime shortly I"ll have a response out to you. : )
Take your time Dauntt, just wanted to confirm that you recieved it and clear the b.s. going on around here. I never said it before, but I do admire you for the hard work you are putting into this site, and I don't want to take away from that, so you have my personal email address, if you have something to say to me, use it, ok?
cool:cool:
