Ok.. I got my tach to work last night. I have a 89 240sx with a rb20det. I had to do a few things:1. 10k resistor on the tach wire. This I had to do to get a tach signal for my aftermarket tach
2. Used a dohc tach gauge from a dohc cluster. Put that gauge in my sohc cluster.
3. used a tach adapter like the link below to convert the 6 cyl pulses to a 4 cyl pulse like the tach is looking for:
http://cgi.ebay.com/ebaymotors...30745
When comparing the tach in the gauge to the megan racing aftermarket tach it is just a little off. It starts off a couple hundred rpms below the aftermarket and around 6k it is about a couple hundred over the aftermarket tach. Close enough for me!
