Tach questions
hvp014
Car: 89 R32 GTR
Hey got my motor set running good and all the instruments work except for the tachometer.
The chassis is a 1990 SOHC KA24e
Is their any conversions I should check or check my wiring first?
secondly I have an after market (auto meter) shift light and I need an ignition coil signal wire, where should I look for one?
Thanks for the help guys
The_Chosen_One
Car: 2009 Subaru Impreza 2.5i
did you swap the SOHC cluster to a DOHC if you did, did you also use the subharness that goes with it?
hvp014
Car: 89 R32 GTR
no im still running the original cluster that came with the car.
Woods Crasher
hvp014 wrote:no im still running the original cluster that came with the car.
You need a DOHC or CA cluster
