tach problems swapped sr20det in to 1990 240sx
scherger_16
Car: 1990 240sx SR20DET, 1993 Nissan D21 pickup
ok i got a 1990 240sx and swaped in the black top s13 sr20det i know the whole thing about putting an after market tach in you hook it up to the yellow with red stripe from your ecu. tried that tach does not work. i also cant find the dohc tach and would rather put in the aftermarket tach i already have. what are my other posibilites for hooking this up i have read many fourm and couldnt find anything. can any one help me is been driving me crazy
Hijacker
Car: '92 240sx Convertible
'94 F-150
Make sure the tach signal coming from the ECU is attached properly to the corresponding wire on the dash connector
scherger_16
i have cheak that i need to know where it could come of the engine. is it possible to go of the number one cylender coil
sam jiggy
Car: 240SX
sheet.
Hijacker wrote:Make sure the tach signal coming from the ECU is attached properly to the corresponding wire on the dash connector
thats all i could say too.
scherger_16
can any one else help me some one told me that you can take it of one of the 4 wires that run to coil number one i dont want to try this and wreak the tack or anythin
scherger_16
followed that wire and it ran to a plug that conected to nothing i took the aftermarket tack and tied it in with ignition coil 1got a signal but it only gave about 1/4 of the signal because its only getting one signal acting as its a one cylender motor rather then 4
