tach not working
wabisuke1
probably something i have done wrong or havent done. i hooked up the red and yellow wires together. im getting power through the plug that connects to the gauge cluster but no tach response. oh and by the coolwhip you were right car handed my *** to me. but it wasnt the fuel pump or the coilpack it was a slow coolant leak that was causing the car to overheat. fixed it and was like a whole new car
Carl H
what chassis is this?
wabisuke1
its an s13 chassis sorry bout that
Carl H
what year?single cam tach cannot read the rb signal.
wabisuke1
well **** its a 90 now i know should i go ahead and get an aftermarket tach? thanks by the way you and your write-ups have helped immensly
Carl H
i can convert your stock tach to read properly...if you're interested pop me an email to the addy in my profile.
wabisuke1
nah im just gonna go with a aluminum dash and fit in some gauge pods its only like 125 but i will be interested in a rom tune real soon. do you have a shop in charlotte do u do dyno tuning
rbchick
Car: RB powered s13.....KA s14
are the wires connected correctly and have all the grounds? i had the same problem.
wabisuke1
all the grounds are connected. wires are right. now im trying to find out how to get the turn signals to work i used the wires in the write up but no luck anybody got any suggestions.
Carl H
turn signals?the efi wiring has nothing to do with the turn signals.plug the hazard switch back in.
