tach. not working now???
jmorasch
Car: 91 Q45 x2
changed the clock and climate control unit sunday. I had noticed a dead bug inside the plastic gauge cluster when I got the car running.so I gently unclipped the plastic cover on the speed-tach cover and blew the bug out lightly wiped the bottom of the unit,without touching the needles. there was a light breeze that blew I noticed the needles moving. never moved the needles myself.now the tach. is maxed out,needle resting on the passenger side of the gauge....how do I fix this???
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
Take off the plastic cover again, move the needle, gently, to the other side...
A pretty cool thing with these gauges, they defy gravity... If you take the cluster out, and hold it upside down, the speedometer needle stays put, if you move it DOWN towards higher speed and let go, it rises back to 0, haha..
jmorasch
Car: 91 Q45 x2
thanks...but I talked with a friend at work and he said to put some R`s on the engine and it should correct itself.sure enough at about 5 it came back to life!!!! Im interested in the mechanics of the tach now???? Hows it work???
