Tach lights wont come on HELP
aaronscomp
Car: s13
Ok when i turn my lights on my tach lights/ dash lights dont come on. They worked fine for about 2 weeks then they just randomly stopped working ive checked the fuse and its fine. Also does anyone no what wire on the back the cluster is for the lights because ill just wire it into the headlight switch if i have too.
LugNut18
Car: 1992 240sx Hatchback
aaronscomp wrote:Ok when i turn my lights on my tach lights/ dash lights dont come on. They worked fine for about 2 weeks then they just randomly stopped working ive checked the fuse and its fine. Also does anyone no what wire on the back the cluster is for the lights because ill just wire it into the headlight switch if i have too.
What happened before they worked fine for two weeks?
aaronscomp
Car: s13
they worked fine for 2 weeks then the next thing i now they dont work
aaronscomp
Car: s13
bump help
liquid_cool
Car: 1990 Nissan 240SX KA24DE-T swap 8.6:1cr, duelsprings, ti retainers,supertech pistons, K1 H-beems balanced internals ect ect
at the back of the cluster is several bulbs that twist out..there super easy to change man if ya know your way around under your dash with your hand..check those and good luck.
aaronscomp
Car: s13
ya i thought about that but i wouldnt think they would all go bad at once idk mabe ill replace them if i can find some laying around
