Tach install
vududoc
Car: drag drift autox
Ok.....im tearing my hair out on an aftermarket tach install.wire 7 is a no goengine bay plug is a no goneg terminal is faintinsight on this please........ looking for resistance values or alternate connections.
fast datsun.......?????no matter how much i poke around its not registering correctly......i looking for values or others with monster tachs.
BoostFab
Car: S13cp, S13fb, S14z
did you tap into the tach signal from the efi harness?
vududoc
egad man could you be more vague?
Carl H
is the efi harness grounded properly?if not then your tach may not work.you need to put the black wire on the rb efi harness (its on one of the white plugs) to ground.
FAST-DATSUN
You must use a autometer tack adapter to make the aftermarket tack read in coil on plug systems..................
vududoc
so theres no work around..on that....:(
