[s3] »
https://forums.nicoclub.com/-u-u9889.html
Thu Apr 01, 2004 10:14 am
My AVC-R taps the ECU RPM signal and gives a perfect signal, I don't know if you might have a bad connection or something.
Always solder your connections, don't cheap out by using the twist and tape method.
ECU would be less messy not cheaper, as you don't have to run wires to the engine bay.
I am not sure which wire on the coil pack, but its the one you clamp your timing light to. If you have one, test it and find out.
