tach in s13 rb20
burninskulls0911
Car: 240sx
i have a hks turbo timer with a tach and i found something on one of the threads on here and i put a 10k resistor from ecu pin 49 wire to pin 7 wire and then to the tach wire on the hks turbo timer and i get nothing does anyone know what i am doing wrong?
mello88
Car: s13
what happens when you wire it up properly, off the Tach pin from the ECU without any jumper wires or resistors? Look at the ECU pinout on FSM page EN-290.
Pin 49 and 59 are +12v to the ECU, dunno what pin 7 is.. But I don't know why you would want to do that with the resistor, where did you read that? Link the thread or post the info here.
burninskulls0911
Car: 240sx
when i wire it to the rpm signal wire (yellow w/red stripe) nothing when i wire it to the ecu pin #7 (which is the rpm signal, also yello with red stripe) nothing and when i do the 10k resistor from ecu pin 49 to 7 like this write up also nothing
Tachometer
* Find your tachometer signal wire from the dash plug. It's the blue wire with orange trace (LO) going into the white and yellow plug in the footwell.
* Coming out of pin 7 on the ECU is a yellow wire with red trace (YR). This is the tacho signal to the ECU. You could splice a wire into this but I'd advise looking in the engine bay and finding a small rounded plug on the afm branch by the passenger strut tower. It has a single wire going into it and a rubber cap on the end. The wire is yellow with blue trace (YL). This is also RPM signal. Run a wire from this plug, into the footwell and attach it to your tacho signal wire you found earlier (LO).
* Now you'll need to go grab a 10k resistor. They're about 6c from d!ck Smiths. You'll need to splice a wire into wire 49 from the ECU, run it through your resistor, and finally splice it into the tacho signal wire.
• Hey presto your tacho works!
Carl H
what chassis is the engine in?
burninskulls0911
Car: 240sx
Carl H wrote:what chassis is the engine in?
it said s13 in the title.....
and im wiring it up to a after market tach not the stock one
burninskulls0911
Car: 240sx
i forgot to add that its a 90 so a single cam chassis sorry about that
