Tach hookup
fastmonteus
Car: 1999 Nissan Frontier
which wire do i splice into to hook a tach up my coil is made into the distributor its a 2.4 dohc thanks tim
Big-Bird
Car: 2000 Xterra on 'Roids & 2004 Quest SL
Shoot..I think you stumped me on that one.....but I have the CD manual so I'm not licked yet!
or am I
Check your yahoo emailfor a 4 page word document from my CD manual
It should help you find what you seek
fastmonteus
big-bird the 4 page thing on the tach hadnt showed up yet thanks tim
Big-Bird
I sent it again
The images are pasted in a MS Word document file. It's under 500K so you should be a quick email.
brdrhoppinpro
Car: 1986 hardbody
hey whats up. i also need the tach information so i can hook that **** up. if you could please send me a copy of that section that would be great! thank you here is my email: [email protected] thanks again!
Big-Bird
Email sent.
Hope it helps
Philalan
Car: 1999 NISSAN FRONTIER - 2 WD 4 CYL AUTO
fastmonteus wrote:which wire do i splice into to hook a tach up my coil is made into the distributor its a 2.4 dohc thanks tim
I Have a 1999 2 wd auto 4 cylinder and want to put a stock Tach in it. Any suggestions?
Big-Bird
Did the 4 cylinder trucks in 99 come with an available Stock Tach? (Anyone know the answer to that one?
I am going to take a guess and say that they did come with a stock tach but you will need to find a gauge cluster from a Nissan truck, hopefully the same year, that did come with a tach and do a swap. The factory wiring might even be there in your trucks dash already. I do not know how the stock tach gets it's signal on the 1999 4-cylinder engine. And I haven't even checked the V6 for that matter either.
Another option: you could find an aftermarket tach and mount it somewhere either on the steering column or on the A pillar. I don't like the idea of mouting them on the dash pad. There's too much foam to get a good solid mounting in my opinion.
If you do get an aftermarket one they should have instructions on where the signal wire needs to be connected in order to get a signal to the tach. Please keep us posted if you decide to pursue this.
