tach ground
gibbo80
my tach has a bad ground, will this be easy to fix?
[Zero-S]
Car: Tell me whats wrong with this picture. 3 240's, only one runs.
do you have a seperate tach? Yeah its actually very easy to fix...if the wire got messed up, just run a new wire, or reground it somewhere else (talking for seperate tachs.). And also a ground point has to be an unpainted surface that in some way shape or form is connected to the chassis.
kansas240
Car: '00 Nissan Xterra 3.3
if it is the stock one, you can remove the wire from the harness with a pin and test the ground to see if it is the connection or the wire
gibbo80
how do i know which one it is, ah ill just leave it i am gonna have to change it for the swap anyways
