IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Sun Mar 07, 2004 2:26 pm
no, a pull up resistor is from positive power.
+12v-------------[10k resistor] tach signal--------------^----------{TACH}
the resistor goes between +12v and the tach signal line. you do not interrupt the tach signal line, you just connect the other end of the resistor to the line before the tach.
what your going to do is place positive power on one end of the resistor, and connect the other end of the resistor to the tach signal line, creating a "3 way intersection"
