i don't have an afc.maryjane wrote:ditch the afc!
can you lead me in the right direct as to what needs to be done? my fab guy is about to brace everything on it and tilt the flange away from the head a little. i can have him do whatever to the wg outlet as wellS14-NEO wrote:man they should throw in warning labels on the box that ship those manifolds in...(WARNING)...i will offer you extreme boost creep...be prepared to modify the outlet for the wastegate cause its not in the proper location in order to maintain boost.
pump gas can take you into the 500s. if that is your goal, i wouldn't bother with the extra meth variablerobbie2883 wrote:haha...the spray bar is just something i had, i had thought of selling it, i'll have the nitrous already on the car though so who knows? the meth....well, there's a difference from running 500 on race gas and 500 on pump! i would hardly call it a cheat!
Modified by robbie2883 at 1:44 AM 7/8/2009
yeah...i thought about head work, but will i really need it for my goals? like i said i'm trying to break 500whp with it and call it a day. i was under the impression i wouldn't need headwork for this. i want reliable on pump gas. besides...for a street beast anything more is pointless on the s-chasis. it's just too light.Largekid wrote:the meth is a nice saftey feature to have, I agree about the spray bar though...that could be put towards some head work Looks like a good start bro.
you should do another GB and i'd consider it! LOLeh? wrote:You should really save yourself a migraine and get a 6boost exhaust manifold. I think you'll be okay without the meth kit as you have 93 octane available and have a built motor.
how will the avcr know when your meth dies out? the whole point of meth is to push timing as if you are on race gas. what signal do you plan to feed to the pfc or avcr which will tell either of the two that your meth has run out or failed? in an off chance say your meth pump fails or you run low on fluid. how will pfc or avcr know that? you'll run the same boost with the meth timing. oops. seems dangerous to me. most meth systems have a warning light or something for low fluid, but it's still up to the driver to see it and stop stepping on it.robbie2883 wrote:i'll be tuning with the PFC, but i'm also gonna tie it into my avcr to run a higher boost level and if the meth dies out for any reason then the avcr will drop the boost
i'd consider it as another variable that could potentially go wrong. quite the opposite of a safety feature.Largekid wrote:the meth is a nice saftey feature to have
i know a better manifold is worth it. but this one was free and i have a good friend that does fab work so making this one work is nothing realy, we've dealt with worse, but i am really contemplating geting a 6boost.Fibre guy wrote:Scrap the manifold. That is the only advice I would give you. It might seem ridiculous to pay as much for a stand alone ecu on a turbo manifold but its well worth it and you get a piece of mind.
itll work if u tune for it. i made over 500 on it, but u just tune for the boost creep (hello 22psi). but being that it creeps itll also affect how you can tune it and your power bandrobbie2883 wrote:
is it really needed though to break 500? i know it will help me reach it easier and more efficiently though. but needed? not trying to argue, this is exactly why i made this thread. for the input of the experienced. who knows, maybe one day i'll do that work. just not big on taking the head off right now. plenty of other projects i'd like to get done on her. just got the ac, now working on cruise and installing some of these toys.mott6904 wrote:Whats the point of doing all the work and then restrict with a stock head. I would seriously consider a good port job on the head. There are tons of improvments to be made on a rb head especially on the exhaust side. good luck
yeah, we were actually thinking of just doing like this guy did to solve teh creep issue. the avcr should also help to keep boost in check as long as the wg is large enough. (i hope! LOL)krayton wrote:
