It's a garrett/turbonetics hybrid.IWannaS15 wrote:As long as the A/R isnt too big, it should spool up decently. I'm guessing somewhere after 4000rpm to make 10psi. (I just pulled those numbers out my arse based on stuff Ive read.)
Neejay, T3 turbines dont come in 0.68 A/R and T04E wheels dont come in 52trim. What kinda weird turbo is that?
Where did you get these maps from? I'm hella confused right nowS13FX wrote:Ok this is kinda confusing hehe are you talking about me? And yah I did some more research today and look at the compressor maps, at 10psi with my setup I should full boost at around 3500 but I guess Il find out by the end of the month. And yes it is a straight T4 I learned that too.
Thank you very much guys. This input is very important to me.
hmm...after examining it, either one of 2 things happened:IWannaS15 wrote:As long as the A/R isnt too big, it should spool up decently. I'm guessing somewhere after 4000rpm to make 10psi. (I just pulled those numbers out my arse based on stuff Ive read.)
The compressor map will tell you very little about when you wil hit 10 psi. The turbine has the boggest influence here. The compressors influence is limited to the rotational weight of the wheel itself and it's efficiency as pressure and air flow climb. The latter being an issue of aerodynamics, which would be quite difficult to calculate without knowing what the turbine and motor are doing. It's not worth trying to calculate this on our level though. Focus on the turbine trim and A/R for your best indication as to how the turbo will spool.S13FX wrote:Ok this is kinda confusing hehe are you talking about me? And yah I did some more research today and look at the compressor maps, at 10psi with my setup I should full boost at around 3500 but I guess Il find out by the end of the month. And yes it is a straight T4 I learned that too.
A 50 Trim T04E turbo is much more capable than 300 HP on a KA. The A/R on the compressor side doesn't have much effect. The 50 Trim would probably push out at least 450 HP if the Engine and fuel system can adequately handle it.Neejay wrote:After a little more research, if it is a 50 trim/.48 A/R, my limit would be about 300hp. I still need to figure out where would the RPM range kick in...
What do you think it'll choke it down to? I hate this guy lied/didn't know what he was talking about. Jeez. He claimed it was .68, but the turbonetics part# is that of a .48.WDRacing wrote:I agree, if it's a .63 AR or bigger hotside. The .48 will choke it. I think you and I are the only people on Nico that aren't afraid of a little lag Chano. You know what they say about the size of a mans toys
WD
I tend to blame the Gran Turismo games for that one. Some of the monster turbo cars you can build have exceptionally bad lag with their biggest turbo kits. While it's possible to get such lag, if you size correctly, it should not be that bad. What's worse is the car does not look like it's accelerating at all until boost comes on. Cars with big turbos will still accelerate much like a NA car until boost hits. The relative difference can be high, but certainly not that bad. To an extent lag rewards you with more power. Case in point, my friend had a Supra TT. 320 HP at the flywheel with some 12 psi out of the factory turbos. Slapped on a HKS T04R single turbo kit and ran 14.5 PSI. 450 HP at the wheels (should be over 500 at the flywheel - probablt at least 529). That's some 200 HP out of 2-3 psi of extra boost. There was noticable lag at lower RPMs but any decent driver should be able to keep this car in the powerband. With some higher boost levels, this kit has reported over 700 RWHP on some Supras. Efficiency on the compressor and turbine sides can yield some big gains. Though, on the Supra, a chunk of the gain is likely in the manifold as the stock mani's are horribly restrictive. But the majority is still on the turbo.WDRacing wrote:I agree, if it's a .63 AR or bigger hotside. The .48 will choke it. I think you and I are the only people on Nico that aren't afraid of a little lag Chano. You know what they say about the size of a mans toys
WD
