T4 A/R same as T3 A/R
DriFt3r
Car: Racing and Drifting
I was wondering if a .63 A/R T4 is the same or bigger then a .63 A/R T3 for the exhaust side.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
The T4 wheel is bigger, so the A/R cannot be compared. Apples to oranges...
Much in the same way you can't compare a "Z31 T3 .63" to a "T3/T4 - Stage III turbine wheel with a .63"...one is obviously bigger, but will have more lag and flow potential.
A/R is dependant on wheel size.
- Brian
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
taken from FAQQuote »A/R Ratios - Area/Radius Ratio... it describes the size of the housing. A larger a/r will make the turbo spool slower but will provide superior flow and thus more top end power. A smaller a/r does exactly the opposite, it spools the turbo quickly and provides semi-adequate flow. There are so many different a/rs out there that allow you to fine tune what you need out of a turbo. [/quote]
C-Kwik
Checkered-Member wrote:taken from FAQ
Unfortunately, this is quite wrong. While the A/R is affected by the size of the housing, it is NOT the size of the housing that it is really a reference to. The A/R really represents the size of the nozzle(the part of the turbine that air goes through before hitting the turbine wheel). A/R stands for Area/Radius. It is the Area of the nozzle in the housing divided by the radius from the center of the turbine axis to the center of the nozzle. A larger wheel will generally push the radius out further naturally. But for a given turbine and matched housing, it is generally only the area of the nozzle that differs from one A/R to the next. The Radius usually stays constant. Someone really needs to fix that FAQ. I have had to correct people on this very topic in many posts within the last month.
Orion is correct that you can NOT make a direct comparison of A/R's between different turbos. A .69 A/R on a T3 turbine is drastically different than a .69 A/R on a T4 turbine. Not to mention there are different trims available in each. Some are so different as to have a different major(outer) wheel diameter. In most cases only the minor(inner) diameter of a wheel changes with different trims.
C-Kwik
Checkered: Where is the FAQ you pulled that from? I don't think I've ever read through it. I'd like to check it out, but I can't find it.
Checkered-Member
C-Kwik wrote:Checkered: Where is the FAQ you pulled that from? I don't think I've ever read through it. I'd like to check it out, but I can't find it.
http://www.nissaninfiniticlub....37527
