Yello!
soooo... as a background - T32 has P0300 and intermittent P0303. been outtatown for a month or so. came back. VERY rough idle, hard to get going, sometimes even stalls.
have two DTCs:
- P0011 - INT/V TIM CONT-B1 (″A″ Camshaft position - timing over-ad-vanced or system performance bank 1)
- P052A - CAMSHAFT POSITION TIMING B1 (Cold start “A” camshaft position timing over-advanced bank 1)
at idle "INT/V TIM(B1) degreesCA" shows 48.5. FSM says it should be around 10, +/-2...
if I slightly apply gas pedal - it all starts sounding really good and smooth.
Oil pressure seems a little bit low like 1600mv (I think few months ago it was more like 1900).
found old post from VStar650CL -
post6853050.html?hilit=P0011#p6853050
from what I googled - suggestions like "just change all three solenoids - intake, exhaust and lock" from guy like Eric the car Guy -
https://www.youtube.com/watch?v=V1yrU-W6h0Y
looked at prices:
https://parts.nissanusa.com/parts/nissa ... 237963ta4a - 110usd
https://www.rockauto.com/en/moreinfo.ph ... 0&pt=12910 - NTK 40usd
https://www.napaonline.com/en/p/NGKVV0157 - at the same time the same NTK VV0157 is 90ish bucks at NAPA...
what are opinions, experiences and suggestions?
