T3 XS Power TURBO QUESTION...
deathBooster
Car: 240sx under construction
Any one have a T3 turbo manufactured by Xs Power installed on a sr20?? Is this turbo any good?? Any one recomend this, it is really cheap...
Modified by deathBooster at 10:29 AM 4/12/2005
Nicksemianiw
Car: JDM 89 Silvia K's
I got a HKS T3. It works fine spools up nicly. You will get 10 more whp if that. Only because it will work more proficantly. The only way that turbo will give you more noticabull power is by cranking up the boost. And to do that you need bigger injectors,A/F controler and a 300zx TT MAFS upgrade. And with that in mind you can make maybe 280-300 whp. HKS makes really nice turbos better then Turbo Xs's turbos. But they are pricey. And if you wait maybe 3 weeks if i am going to part out my car i can sell you my manifold and HKS T3 Turbo for 750 American. Has a internal waste gate, really loud when it it spooling and can support 400whp
Nick
EDIT: There is no shaft play and is a direct bolt on (replacment for the T25 turbo on the sr20det)
deathBooster
so, you selling your car?? what other parts you selling??? I am interested... let me know.. what is your setup? did you dynoed???
Nicksemianiw
I'm not selling my car i am just building the motor now so i have no need for my T3 because it only supports 400whp;) and i will be selling other stuff like my turbomanifold,hotpipe stock injectors stock fule rail, boost controler. those are the main things i am selling
