First off, WD, if you see fit, delete my responses, as it pretty much goes off topic, but I couldn't resist. It might be more appropriate to move Chaotic's and my posts to a new thread.
Chaotic_Warlord wrote:Just out of curiosity and I may be off base here but If you take a stock KA with say 60K on it and drop a T28 onto it will it produce the same amount of power or more power than a AK with say 140K? Does the age and condition of the engine have any bearing on the power output?
This rings true with any engine. Ring wear and blowby have a direct impact on an engine's power output in any situation, be it forced induction or natural aspiration.
Chaotic_Warlord wrote:Now lets say you take that same T28 and mount it onto a fully built KA block shouldn't it produce more power? Your HP should rise depending on what compression ratio you have, so to take a T28 off a black top SR that has a cr of 8.5 or 8 and mount it on a 9.5 or 9 cr stock KA block you wont see the same 250hp you did on the SR you're hp rating will drop in conjuction with your compression ratio.
The CR in boost has little to do with power output. It really has more to do with off-boost operation.
Chaotic_Warlord wrote:Also take into account what other mods you have done to your car wneh try to make a ballpark HP guess, is there a more aggressive cam setup on the car, is your fuel setup right, ect...
These have nothing to do with whether a T2 footprint is appropriate for the KA.
Chaotic_Warlord wrote:If you are on a budget and don't have the funds to fork out the money for lower compression cams there is always the headgasket trick, but even this only works to a certain point, and it's not a permanent fix, its just a temporary way to squeeze a little bit more out of the stock setup on a budget.
For those that don't know the headgasket trick there was a very good explanation of it in Sport Compact Car a month or 2 ago. Some guy asked about doing it on an S2k and Joquiot explained it in depth and in laymans terms, I'll have to check it when I get home and give you guys the actual issue, I believe it was the october issue. But the basic jist of the idea is that the thicker the headgasket the lower compression you'll have, so if your stock head gasket thickness is .002 then if you replace it with a .005 headgasket your cr would drop like .5, don't quote me on that i'll get back to you on the actual issue and quote what was said.
While still being off topic (T2 vs. T3), I'll have to return an argument for this (sorry WD).
It's been proven that using a thicker headgasket on a stock deck height (not milling the deck to accept the gasket) results in a knock-limited engine on low boost applications. The issue is that the combustion chamber is moved too far from the piston to maintain the quench zone. Consequently, the intake charge is allowed to "wander", if you will, to the outer edges of the cylinder, rather than being contained in the combustion chamber. Once this happens, hotspots are created and the engine is more prone to knock before reaching MBT (mean best torque). Higher boost applications don't necessarily suffer this dilema.
Chaotic_Warlord wrote:As tempting as it is for me to boost the stock engine, I've read about to many popping their engine to make it comfortable fo rme to hold the notion with any great confidence. I would rather build the block and just wait for the boost.
The things that blow stock engines are the same things that blow fully built engines. Primarily, poor tuning is the culprit. My 200+k mile stock KA would be a good example of a well boosted engine that survived just fine.
