thekawaii wrote:Q1: I got a T3 turbo from Z31, but there are 2 holes on a turbo, one for water, one for oil. But seller did not included a water line...... so do i need to get water line from Z31? or should i just run oil line only?
How long do you want your turbo to last? How reliable do you want your setup to be? You just answered your own question if you answered mine.
thekawaii wrote:Q2: Wastegate open at 12 psi, is it too high for my engine? (My goal is 250 HP, or 5sec 0-60)
Perhaps if you are running stock injectors & MAF - they will max out around there. I'm not sure about the straight up t3, but for t3/t4, that's too high for fuel & such.
Basically, just start lower and tune up. Or just drive carefully to the dyno, you will only know how much your engine can handle after tuning it & driving it.
thekawaii wrote:Q3: should i just stay with 7psi, make around 200hp, be happy, uses stock injector and MAF with NO SAFC?
You could, but you will 99.99% get that "just a couple more psi" itch after about a week :-D.
thekawaii wrote:Q4: This's a real dumb question but is there any website i can learn how to install turbo? (Yes i know, i can figure it out, but since this's the first time i'm playing with turbo, i just want to make sure that i'm installing it properly, i know it shame on me, i was in auto class for a year but didn't learn anything about turbo.)
Um, I hope you at least have read and know how turbo's work....... To install it, it's relatively easy if you search the gagillion threads on here.
Better yet, why not ask the seller, he's a member on this forum, he can tell you exactly where everything goes since it's his setup.
Basicalllly:
unbolt your old stuffput in new injectors/pump if you have itput on manifold turbo downpipe etcrun the oil/water linesrun the intercooler pipinginstall any sort of engine management
Since his setup was already complete, you should be able to install it ok... it's tuning that's a *****.
