t3 turbo Q's
kapower06
I recently recieved my t3 super 60 turbo.... Looks to be the exact same turbo from boost designs. Im wondering what I need to do as far as a downpipe and a pipe for the intake on the compressor side. For the intake with the 2-bolt flange I found that a stock sr20 elbow will fit, but I cant find any for sale. Does anyone know if the z31 t3's had this 2 bolt intake. Also for the downpipe I assume that I'll need to make a custom one with a 3 bolt flange and some steel pipe, as it's internally gated. Any help would be great.
thanks -Jake
kapower06
bump b4 bed
Jookmasta
well to help u out, the intake flange ur looking for can also b sourced from a GN's turbo. They call it a bell housing so search for one on ebay or the rest of the net. As for the DP, i had to have my DP welded directly onto the swingvalve portion of the back of the turbo. Its connected by five bolts. ill try to take pics tomorrow but i dont know how to post pics. lol. hope this helps
Tictakman
here are some flanges for the dp...http://www.atpturbo.com/Mercha...e=FLS
i cant rem where i got my adapter for the intake of the turbo. if i do ill post.
Zak
WDRacing
Jookmasta wrote:well to help u out, the intake flange ur looking for can also b sourced from a GN's turbo. They call it a bell housing so search for one on ebay or the rest of the net. As for the DP, i had to have my DP welded directly onto the swingvalve portion of the back of the turbo. Its connected by five bolts. ill try to take pics tomorrow but i dont know how to post pics. lol. hope this helps
They have to be hosted on the internet somewhere. Fortunatly for you NICO has free pic hosting. Click on the link that I made a sticky at the top of the forum. It is super easy to load pics right from your pc. Then, once the pic is on the internet, open the pic up, right click on it, open the properties tab, then copy the web address. Make a new post here or wherever, click on the add image button. It will place these [img img] on the screen for you. These are image tags, its HTML code for being able to host a picture. Simply insert your pic between them, like this [img yourpicgoeshere /img] then finish the post like normal. I left out two of the symbols so you could see what the image tags would look like. If you don't all that comes up is a red X. That may confuse you a tad.
If you can't get it to work, email them to me and I'll host them for you in my photo album. Mostly cause I'm the coolest moderator ever.
Hit me up on AIM sometime I'll talk you through it.
WD
