Jookmasta »
https://forums.nicoclub.com/jookmasta-u6633.html
Wed Jan 26, 2005 5:43 pm
um for the oil line question, if ur oil feed line is -3AN and have female swivel fittings at the end of them, then usually u will need an adapter so that the line can connect to the oil inlet on the turbo. for me i know i had to get an adapter which had a -3AN flare male on one side and 1/8 NPT male on the other side.
for the internal wastegate question, i personally would like to know more about this as my turbo is also internally wastegated. me and a local buddy messed with the rod and stuff a couple days ago but we were just looking at the wastegate to see where the flapper sits. do all internal wastegates have rods which can screw in or screw out? i know i know sounds noobish but my turbo is a factory turbo so who knows. im gonna pull it up tomorrow and try it out. If it does work, would that technically be the only way to lower the boost on an internal wastegate besides using an EBC?
Last but not least, the actuator on mine is hard to pull down also so i think its suppose to be like that wild maxx. ive felt some other factory turbo and they did require some pressure to move the actuator.
