t3 turbo inlet gasket
White Comet
Car: fc, s13 and mazda6, Sierra
pretty simple and straightforward, i'm trying to find a place that sells a turbo inlet gasket thats t3 sized. did and little searching and found nothing, just wondering what other people with t3 turbos are using.
KA720
Car: RB powered s13
you can order it from nissan, part # 14415-4P200, it's for a z31
White Comet
orly? i wasnt aware that was a t3 flanged turbo
KA720
Car: RB powered s13
yup it is, I had a gasket from a z32 in stock which I know is a t2 flange and one from a z31 in stock, and measured them and sure enough the z31 is the bigger gasket, so I'm sure it's a t3 flange
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
http://www.google.com/search?h...=f&oq=
There you go, pretty straight foward just like you said.
White Comet
yeah i know its straightforward, but i guess i should have mentioned that i'm looking for good quality gaskets. i found t3 gaskets on ebay but i don't trust them not to blow out. its good to know about the z31 gasket thats where i'll be getting it from then. thank you
blacksrjdm
KA720 wrote:you can order it from nissan, part # 14415-4P200, it's for a z31
Or get the Z32 from nissan part# 14415-17M00.
White Comet
i'm certain the z32 is t2 flanged cuz thats what i got for my stock t25
KA720
Car: RB powered s13
the z32 gasket is a t2 flange, but the oem gaskets are very good gaskets, it's almost like a plate of metal, lol, none of that paper crap, but to be clear you have to get the z31 gasket
blacksrjdm
Are the Z31's outlet different from the Z32's. I believe I have used both as replacements for my stock SR gasket. The pics on my FAST look the same.
KA720
Car: RB powered s13
nope, the picture does look the same in FAST but it list two different part numbers, you are talking about the exhaust side outlet right? if you are talking about the triangle shaped gasket that is on the cold side of the turbo, then yes you are right they are the same between the z31 and z32
blacksrjdm wrote:Are the Z31's outlet different from the Z32's. I believe I have used both as replacements for my stock SR gasket. The pics on my FAST look the same.
blacksrjdm
No I meant the 4 hole manifold to turbo gasket.
U might be right though, because just looked up an N12 pulsar turbo, and that has the same part# as the Z32 gaskets so, must be different than the Z31. Good job, Somethin for me to remember.
KA720
Car: RB powered s13
yeah the z31's are definately the bigger T3 flange
White Comet
good to hear that the z31 gasket is definetly what i need. i called my local dealership with the part number and it'll be in on tuesday. its like $18. i'm am certain though that z32 is the smaller t2
KA720
Car: RB powered s13
so did you get the gasket you were lookin for?
White Comet
yep the z31 gasket did the trick. thanks for the help guys
