Just to let you know the Corvette has a curb weight of 3100lbs. and puts nearly down somewhere in the neighborhood of 360whp.Edub1 wrote:That is why a 2005 Corvette with about 290HP at the rear wheels and a 3,700lb curb weight will pull a 12.5 second 1/4 mile. Plus, I hate the thought of beating my motor twice as hard to make up for lost time.
The 2006 Corvette dropped to 3100lbs. The 2005 was 3700lbs and 350 SAE net HP at the crank. The 2006 Z06 has 500HP but it's also $70,000 at the onset.Jimmyg41 wrote:
That being said, I agree with Nissanfanatic, the TO4E is a much better turbo all around and it has more potential for future boost applications. A lot of people star boosting low but once they do they get bit by the boost bug and keep aiming higher.
My stock KA runs like a raped ape - I have nothing but confidence in her. I'm just afraid that the boost bug might bite me in the arss if I'm sitting on that To4E.Jookmasta wrote:i run the t3 60 trim..................lag is needless to say nonexistant. i get full boost whenever i want it in whatever gear i want. be wary that u will need the .63 a/r exhaust housing cuz the t3 will NOT be able to make the numbers a t04e can in the long run. like it was said earlier, the t04e gives u room to play if the boost bug bites u. do a compression check to see how ur motor is doing. i went turbo at around 142K so dont think 100K is alot of miles if ur motor was taken care of or is currently in good shape.
Not to drag this on, but the 2005 models were of the new body style aswell, so I'll just assume you meant the 2004's as they had the old LS1's with the 350hp. They weigh around 3,200.Edub1 wrote:The 2006 Corvette dropped to 3100lbs. The 2005 was 3700lbs and 350 SAE net HP at the crank. The 2006 Z06 has 500HP but it's also $70,000 at the onset.
Back to the topic...
I'm thinking that if I boost higher than about 12lbs I'll blow my motor.
Actually, both turbos hit 74% efficiency at about the same boost level. It will occur at a higher airflow rate on the T04E 50, but the T3 tends to be on the inefficient side on a KA at higher RPM regardless of boost. At about 12 psi. the T04E 50 will cross through the 78% efficiency island, where in the T3 60, the most you may see is 75%. And most of that will occur in the midrange, dropping to 70% or so by redline. The T04E 50 will only see as low as about 76% at redline.Edub1 wrote:So, I'm thinking that I might be better of with a T3 60 trim that will spool quicker and run more efficiantly at the lower boost & rpm levels. Let us not forget that lag time is lost time and that time can add up quick.
Your right, I'm thinking 2004 and they are 32480. I was a little off on the 1/4 mile too - 12.98. But that's still some damn good numbers for 350HP. Anyway, you guys talked me into it. I'm going T04E 50 trim. So if I send my cyliner head into orbit I can blame it on all of you.SeVa-S13 wrote:
Now onto the issue...if you're worried about spool time, just go with the .48 a/r turbine. Sure you'll limit some topend but you're obviously not after pure performance, just a more powerful and fun daily. The 50 trim T04E is such a great budget compressor and I've used it on two different engines and have loved it both times. The 50 trim is considerably more efficient all over than the 57 trim and creates boost sooner too. The super 60, while being a great T3, is still a smaller compressor, meaning less efficient and higher temps at full boost, meaning more stress on the engine.
Thanks...turbos will always fascinate me. Such a simple device in the mechanics, yet so deceptively complex in application. I'm still a KA-T guy at heart. Unfortunately the law gets in teh way of so many of my pleasures...WDRacing wrote:Chano, good to see you're still around to help out. I thought we lost you to the darkside forever.
